Backpack Roller Pro offers first-class functionality and true elegance. The perfect 2-in-l notebook backpack and travel trolley combination. Well cushioned shoulder straps, which can be concealed with a zip cover, are ready to use when required. The robust two-stage telescopic handle allows to convert the backpack into a trolley within seconds and to be pulled along on its easy-running, replaceable wheels. Special protective wheel-covers prevent clothing getting dirty whilst using as a backpack.
- DICOTA Backpack Roller Pro - notebook carrying backpack/trolley
- Product Type
- Notebook carrying backpack/trolley
- Product Material
- Polyester
- 36.5 cm x 23 cm x 50 cm
- 3.3 kg
- Notebook Compatibility
- 17.3"
- Ownership tag, zippered, cord management system, High-Density Foam (HDF), wear-resistant, 2 zippered front pockets, RFID blocking pocket, wheel cover, wet pocket, water repellent, lockable notebook compartment
- Carrying Strap
- Shoulder carrying straps, top carry handle
- Telescopic Handle / Wheels
- Product Type
- Product Material
- Polyester
- 36.5 cm
- 23 cm
- 50 cm
- 3.3 kg
- 17.3"
- Notebook Compatibility Dimensions
- 41.5 cm x 28 cm x 4 cm
- Additional Compartments
- Passport, documents, keys, mobile accessories, tablet
- Carrying Strap
- Capacity
- 40 litres
- Wheels Qty
- 2
