Dicota Backpack Rain Cover Universal
Quicklinx: FS21WS00 Mfr#: D31106
The coated, particularly durable material keeps you dry even in heavy rain. The Raincover Universal can be installed with a few simple steps. Simply draw the protective cover over your backpack. The elastic material fits the contours perfectly. Two elastic bands, which are pulled under the shoulder straps and fastened with a button, are provided for extra stability. The rain cover not only provides reliable protection against moisture but also ensures good visibility on the road.
DICOTA Backpack Rain Cover Universal - raincover
Raincover
Protection
Waterproof
Product Material
Polyester, Oxford fabric
200 g
Raincover
Protection
Waterproof
Product Material
200 g
Lifetime
