From yoga classes to the office, MOVE is designed for daily use. It is comfortable thanks to its ergonomic back cushioning and cushioned shoulder straps with an adjustable chest belt. Perfectly maneuver your backpack thanks to the two handles for carrying. The fabric is made of water-repellent materials but in case of thunderstorms, the backpack also includes a rain cover with a reflective DICOTA logo. The primary storage area contains a notebook compartment cushioned with High Density Foam (HDF), a padded slip pocket for tablets up to 10.5 inches, a divider for documents and an elastic mesh pocket to hold your drink bottle. The second main compartment contains dividers for headphones and folders.
- DICOTA Backpack MOVE - notebook carrying backpack
- Product Type
- Notebook carrying backpack
- Light grey
- Product Material
- 300D polyester
- 30 cm x 17 cm x 48 cm
- 800 g
- Notebook Compatibility
- 15.6"
- Notebook Supported Sizes
- 13" - 15.6" / 33 cm - 39.6 cm
- Adjustable straps, slip pocket, YKK zipper, 10.5" tablet support
- 30 years warranty
- Product Type
- Product Material
- 300D polyester
- 30 cm
- 17 cm
- 48 cm
- 800 g
- 15.6"
- Notebook Compatibility Dimensions
- 38.5 cm x 26.5 cm x 3.5 cm
- Capacity
- 24 litres
- Light grey
- Limited warranty: - 30 years
