Dicota Backpack GO 13-15.6 - Light Grey
Quicklinx: FS1VWS00 Mfr#: D31764
Stylish and functional, this original daypack holds your gym and work essentials. The Backpack GO is comfortable to carry thanks to its ergonomic back cushioning and padded shoulder straps with an adjustable chest belt. It also includes a handle for carrying. The open front compartment expands easily to fit anything you need. Pack your sports shoes, cycling helmet or wet sports clothes and easily secure them with the metal hook and compression straps on the sides.
DICOTA Backpack GO - notebook carrying backpack
Notebook carrying backpack
Light grey
Product Material
300D polyester
32 cm x 14.5 cm x 48 cm
800 g
Notebook Compatibility
15.6"
Notebook Supported Sizes
13" - 15.6" / 33 cm - 39.6 cm
Water repellent
30 years warranty
Product Material
300D polyester
32 cm
14.5 cm
48 cm
800 g
15.6"
Notebook Compatibility Dimensions
38.5 cm x 26.5 cm x 3.5 cm
Water repellent
22 litres
Light grey
Limited warranty: - 30 years
