Dicota Backpack Gain Wireless Mouse Kit
Quicklinx: FC2SWS00 Mfr#: D31719
£27.91 ex VAT
£33.49 inc VAT
Thanks to the lockable notebook compartment, the Backpack Gain lets you carry your notebook securely and comfortably. The spacious main compartment offers plenty of room to store your personal belongings. Accessories such as pens or smartphone can be placed in the front pocket. The detailed workstation helps to keep everything in the right place.
Furthermore, this backpack features a practical slot for tablets up to 10.5". With its breathable back padding and padded shoulder straps, Backpack Gain is the perfect companion for comfortable transportation.A stylish, wireless mouse design scores well in any kind of business environment with its optical LED sensor featuring a resolution of 1000 dpi. Three buttons including the scroll function make for easy handling.
  • 1000 dpi, 3 buttons optical wireless mouse
  • Padded and lockable notebook compartment up to 15.6"
  • Padded slip pocket for tablets up to 10.5"
  • Adjustable shoulder straps and compression straps at sides
  • Made of durable water repellent material
  • Ergonomic padding at the back
DICOTA - notebook carrying backpack
Notebook carrying backpack
28.5 cm 40 cm
620 g
Notebook Compatibility
15.6"
Water repellent
Carrying Strap
Top carry handle, compression straps, adjustable shoulder strap
Bundled with
Wireless optical mouse
28.5 cm
40 cm
620 g
15.6"
Notebook Compatibility Dimensions
38.5 cm x 3.5 cm x 26.5 cm
Carrying Strap
22 litres
Bundled with
Water repellent
Brand: Dicota
