Dicota Backpack Dual Plus EDGE 13-15.6 - Light Grey
Quicklinx: FS1RWS00 Mfr#: D31716
Simplicity. Functionality. Inspired, contemporary design. These are the guiding principles that define the EDGE product family. Exceptional materials, colors and highlights accentuate your own individual style. The Backpack Dual Plus EDGE convinces by its versatility. The intelligent backpack/toploader combination is designed to fit MacBooks and Ultrabooks but offering maximum protection to other notebooks. The padding made of EVA foam within the notebook compartment perfectly adapts to the contours of your device and an elastic fastening strap keeps your notebook securely in place.
You can easily switch between using it as a shoulder bag and backpack - without compromising on ergonomics. With just a few simple steps the backpack transforms into an elegant shoulder bag. Therefore, simply stow the carrying straps within the back panel and install the padded shoulder strap. The cushioned and length-adjustable shoulder straps ensure comfortable transportation. Perfect for business trips and weekends due to its 29 liters. A comfortable carrying handle on the long side of the bag provides additional travel flexibility and the functional back panel can be used to attach the Backpack Dual Plus EDGE to a trolley handle - pure mobility. The generous main compartment offers space for documents and features an internal zip pocket for accessories, as well as a generous zipped divider with fixation strap to hold your clothes and laundry in place when traveling. Your tablet (up to 10.5") can be safely stored in the padded slip pocket. The practical and easy-access insert pockets in the front compartment allow you to organize your personal equipment such as cables, business cards, IDs and smartphone. In the additional zip pocket at the front panel other important accessories are to hand at all times. Use the two practical side pockets for water bottle, umbrella or keys for quick access.
DICOTA Backpack Dual Plus EDGE - notebook carrying backpack
Notebook carrying backpack
Light grey
Product Material
Polyester, ethylene vinyl acetate (EVA)
29.5 cm x 21 cm x 42.5 cm
1.19 kg
Notebook Compatibility
15.6"
Notebook Supported Sizes
13" - 15.6" /
Shockproof, EVA padding, transformable into a briefcase
Carrying Strap
Side carry handle, removable shoulder strap, adjustable padded shoulder straps
Product Material
29.5 cm
21 cm
42.5 cm
1.19 kg
15.6"
13" - 15.6" /
Notebook Compatibility Dimensions
38.5 cm x 26.5 cm x 3 cm
Additional Compartments
Headphones, documents, tablet, accessory pocket, zippered front accessory pocket, 2 x side pocket
Carrying Strap
Closure Type
Zipper
29 litres
Light grey
Limited warranty: - lifetime
