The microbial filters reduce bacteria, reflections caused by sunlight and protect the screen from scratches.
The DICOTA antimicrobial film fulfils a variety of functions: it protects the display from scratches, reduces annoying fingerprints, minimises bacteria and is easy to attach. The film adheres directly to the full surface of the display thanks to the use of a silicone layer. The hardened coating on the filter provides long-term protection that continuously inhibits the growth of microbes over a long period of time.
The filters are made with the latest laser cutters and cut to the right size with maximum reliability. The filter is extremely easy to fit. It takes just a few seconds for it to adhere to the full surface of the display and begin carrying out its functions. No more scratches, bacteria, fewer annoying fingerprints and a high degree of anti-reflection coating for your display. It can be easily removed at any time without leaving any residue. This is a quality German product you can rely on, and is simple and handy to use.
Enhanced durability
Featuring a 2H hard-coating, this notebook anti-microbial filter is designed to resist scratches, ensuring long-lasting protection for your device. -
Optimal viewing
With accurate color reproduction and an anti-reflection coating, users enjoy a clear view without glare, enhancing the visual experience on their 12.4-inch notebooks. -
Hygienic screen environment
This product is engineered to reduce bacteria on your device's screen, thanks to its anti-microbial properties, promoting a cleaner and healthier usage. -
User-friendly installation
The adhesive, easy-to-install feature, combined with a residue-free silicone layer back, makes application and removal straightforward, without leaving any sticky residue behind. -
Touch compatibility
Designed to be touch capable, this filter allows for uninterrupted touchscreen functionality, ensuring users can interact with their devices seamlessly.
- DICOTA - notebook anti-microbial filter - 2H
- Product Type
- Notebook anti-microbial filter - 2H
- Installation Type
- Adhesive
- Black
- Product Material
- PET
- 27.3 cm 20.3 cm
- 24 g
- Notebook Compatibility
- 12.4"
- Silicone layer back, touch capable, 2H hard-coating, clear view, accurate colour reproduction, residue free, reduce bacteria, anti-reflection coating, easy-to-install
- 2-year warranty
- Designed For
- Microsoft Surface Laptop Go, Laptop Go 2, Laptop Go 2 for Business, Laptop Go 3, Laptop Go 3 for Business, Laptop Go for Business
- Product Type
- Product Material
- PET
- 27.3 cm
- 20.3 cm
- Thickness
- 0.135 mm
- 24 g
- 12.4"
- Black
Display Filter
- Installation Type
- Adhesive
- Scratch Resistant
- Limited warranty: - 2 years
- Designed For
