Dicota Antimicrobial filter 2H for iPad 10.9 2022 (10th Generation)
Quicklinx: HG5SWS00 Mfr#: D70640
£18.95 ex VAT
£22.74 inc VAT
The DICOTA antimicrobial film fulfills a variety of functions: it protects the display from scratches, reduces annoying fingerprints, minimizes bacteria and is easy to attach. The film adheres directly to the full surface of the display thanks to the use of a silicone layer. The hardened coating on the filter provides long-term protection that continuously inhibits the growth of microbes over a long period of time.
The filters are made with advanced laser cutters and cut to the right size with maximum reliability. The filter is extremely easy to fit. It takes just a few seconds for it to adhere to the full surface of the display and begin carrying out its functions. No more scratches, bacteria, fewer annoying fingerprints and a high degree of anti-reflection coating for your display. It can be easily removed at any time without leaving any residue. This is a quality German product you can rely on, and is simple and handy to use.
DICOTA - screen protector for tablet - antimicrobial filter, 2H, self-adhesive
Screen protector - film
Intended For
Tablet
Installation Type
Adhesive
Protection
Scratch-resistant, fingerprint-proof, antibacterial, anti-reflective, fungus-resistant
Coating
Antimicrobial
Package Content
Screen protector, cleaning wipe
Product Material
PET film (2H)
24.4 cm 17.5 cm
Thickness
0.135 mm
10 g
Apple 10.9-inch iPad (10th generation)
Intended For
Tablet
Installation Type
Adhesive
Protection
Package Content
Product Material
PET film (2H)
Coating
Antimicrobial
24.4 cm
17.5 cm
10 g
Thickness
0.135 mm
SGS
Brand: Dicota
