The microbial filters reduce bacteria, reflections caused by sunlight and protect the screen from scratches.
The DICOTA antimicrobial film fulfils a variety of functions: it protects the display from scratches, reduces annoying fingerprints, minimises bacteria and is easy to attach. The film adheres directly to the full surface of the display thanks to the use of a silicone layer. The hardened coating on the filter provides long-term protection that continuously inhibits the growth of microbes over a long period of time.
The filters are made with the latest laser cutters and cut to the right size with maximum reliability. The filter is extremely easy to fit. It takes just a few seconds for it to adhere to the full surface of the display and begin carrying out its functions. No more scratches, bacteria, fewer annoying fingerprints and a high degree of anti-reflection coating for your display. It can be easily removed at any time without leaving any residue. This is a quality German product you can rely on, and is simple and handy to use.
Enhanced durability
Featuring a 2H hard-coating, this notebook anti-microbial filter is designed to resist scratches, ensuring long-lasting protection for your device's display. -
Optimal viewing
With accurate color reproduction and an anti-reflection coating, this filter provides a clear view under various lighting conditions, making it ideal for both indoor and outdoor use. -
Hygienic screen protection
Equipped with anti-microbial properties, this filter helps reduce bacteria on your device's surface, promoting a cleaner and healthier usage environment. -
User-friendly installation
The self-adhesive design, complemented by a silicone layer back, allows for easy, residue-free application and removal, offering a hassle-free experience for users. -
Touch compatibility
Designed to maintain the touch screen's responsiveness, this filter ensures that your device remains fully functional, providing protection without compromising on usability.
- DICOTA - notebook anti-microbial filter - 2H
- Product Type
- Notebook anti-microbial filter - 2H
- Installation Type
- Adhesive
- Black
- Image Colour Disclaimer
- The displayed product image may be a different colour
- Product Material
- PET
- 29.35 cm 20.3 cm
- 14 g
- Self-adhesive, silicone layer back, touch capable, 2H hard-coating, clear view, accurate colour reproduction, residue free, reduce bacteria, anti-reflection coating, easy-to-install
- 2-year warranty
- Designed For
- HP Elite x360 830 G9 Notebook
- Product Type
- Product Material
- PET
- 29.35 cm
- 20.3 cm
- Thickness
- 0.135 mm
- 14 g
- Black
Display Filter
- Installation Type
- Adhesive
- Scratch Resistant
- SGS
- Limited warranty: - 2 years
- Designed For
