Dicota Antimicrobial filter 2H for Dell U2722DE, self-adhesive
Quicklinx: HG2PWS00 Mfr#: D70616
£61.05 ex VAT
£73.26 inc VAT
The DICOTA antimicrobial film fulfills a variety of functions: it protects the display from scratches, reduces annoying fingerprints, minimizes bacteria and is easy to attach. The film adheres directly to the full surface of the display thanks to the use of a silicone layer. The hardened coating on the filter provides long-term protection that continuously inhibits the growth of microbes over a long period of time.
The filters are made with advanced laser cutters and cut to the right size with maximum reliability. The filter is extremely easy to fit. It takes just a few seconds for it to adhere to the full surface of the display and begin carrying out its functions. No more scratches, bacteria, fewer annoying fingerprints and a high degree of anti-reflection coating for your display. It can be easily removed at any time without leaving any residue. This is a quality German product you can rely on, and is simple and handy to use.
DICOTA display anti-microbial filter - antimicrobial, 2H
Display anti-microbial filter
Installation Type
Adhesive
Product Material
PET
60.83 cm x 0.0135 mm x 34.15 cm
70 g
Dell UltraSharp U2722DE
Product Material
PET
60.83 cm - 0.0135 mm - 34.15 cm
70 g
Display Filter
Installation Type
Adhesive
Scratch Resistant
Anti-reflective, easy-to-remove, bubble-free installation, scratch-resistant, fingerprint-proof, silicone layer back
SGS
Brand: Dicota
