Dicota Antimicrobial filter 2H for DELL Latitude 9510 2in1, self-adhesive
Quicklinx: HG5PWS00 Mfr#: D70609
£25.51 ex VAT
£30.61 inc VAT
The DICOTA antimicrobial film fulfills a variety of functions: it protects the display from scratches, reduces annoying fingerprints, minimizes bacteria and is easy to attach. The film adheres directly to the full surface of the display thanks to the use of a silicone layer. The hardened coating on the filter provides long-term protection that continuously inhibits the growth of microbes over a long period of time.
The filters are made with advanced laser cutters and cut to the right size with maximum reliability. The filter is extremely easy to fit. It takes just a few seconds for it to adhere to the full surface of the display and begin carrying out its functions. No more scratches, bacteria, fewer annoying fingerprints and a high degree of anti-reflection coating for your display. It can be easily removed at any time without leaving any residue. This is a quality product you can rely on, and is simple and handy to use.
DICOTA - notebook anti-microbial filter - 2H
Notebook anti-microbial filter - 2H
Installation Type
Removable - adhesive
Product Material
PET
33.65 cm 19.85 cm
16 g
Fingerprint-resistant coating, bubble-free installation, silicone layer back, touch capable, clear view, accurate colour reproduction, reduce bacteria, anti-reflection coating
Product Material
PET
33.65 cm
19.85 cm
Thickness
0.205 mm
16 g
Display Filter
Installation Type
Scratch Resistant
SGS
Limited warranty: - 2 years
Brand: Dicota
