Dicota Antimicrobial filter 2H for DELL Latitude 7320 detachable, self-adhesive
Quicklinx: GQL3WS00 Mfr#: D70440
£19.32 ex VAT
£23.18 inc VAT
The DICOTA antimicrobial film fulfils a variety of functions: it protects the display from scratches, reduces annoying fingerprints, minimizes bacteria and is easy to attach. The film adheres directly to the full surface of the display thanks to the use of a silicone layer. The hardened coating on the filter provides long-term protection that continuously inhibits the growth of microbes over a long period of time.
The filters are made with the latest laser cutters and cut to the right size with maximum reliability. The filter is extremely easy to fit. It takes just a few seconds for it to adhere to the full surface of the display and begin carrying out its functions. No more scratches, bacteria, fewer annoying fingerprints and a high degree of anti-reflection coating for your display. It can be easily removed at any time without leaving any residue. This is a quality German product you can rely on, and is simple and handy to use.
DICOTA - notebook anti-microbial filter
Notebook anti-microbial filter
Installation Type
Removable - adhesive
Transparent
Product Material
PET
28.4 cm 20.3 cm
30 g
Anti-reflective, bubble-free installation, self-adhesive, fingerprint-proof, silicone layer back, touch capable, 2H hard-coating
Dell Latitude 7320 Detachable
Product Material
PET
28.4 cm
20.3 cm
Thickness
0.155 mm
30 g
Transparent
Display Filter
Installation Type
Scratch Resistant
Limited warranty: - 2 years
Brand: Dicota
