Dicota Antimicrobial filter 2H for Apple iPad Air 13.0 2024, self-adhesive
Quicklinx: HV3GWS00 Mfr#: D70843
£22.05 ex VAT
£26.46 inc VAT
The DICOTA protective film fulfils a variety of functions: it protects the display from scratches, reduces annoying fingerprints and is easy to attach. It also provides a non-reflective coating for high-resolution displays, guaranteeing a clear view. This makes the anti-glare film the number one choice for you. The film adheres directly to the full surface of the display thanks to the use of a silicone layer.
The anti-glare filters are made with the latest laser cutters and cut to the right size with maximum reliability. The filter is extremely easy to fit. It takes just a few seconds for it to adhere to the full surface of the display and begin carrying out its functions. No more scratches, fewer annoying fingerprints and a high degree of anti-reflection coating for your display. It can be easily removed at any time without leaving any residue. This is a quality German product you can rely on, and is simple and handy to use.
  • Effective antimicrobial protection
    The antimicrobial filter included in the DICOTA screen protector actively helps to reduce the presence of bacteria on the screen surface, contributing to better hygiene and safety for users.
  • Easy application with self-adhesive design
    Designed for simplicity, the self-adhesive film allows for quick and hassle-free installation, ensuring a perfect fit for your tablet screen without bubbles or misalignment.
  • Resistant to scratches and fingerprints
    The screen protector is crafted from a durable PET film, providing reliable protection against scratches while also resisting fingerprints, keeping the display clean and clear.
  • Enhanced visibility
    Featuring an anti-reflective coating, the screen protector minimizes glare, allowing users to enjoy their tablet experience without distraction, even in bright environments.
DICOTA - screen protector for tablet - 2H, self-adhesive
Screen protector - film
Intended For
Tablet
Protection
Scratch-resistant, fingerprint-resistant, antimicrobial
Coating
Anti-reflective
Package Content
Screen protective film, cleaning wipe
Product Material
PET film (2H)
21.1 cm 27.66 cm
Thickness
0.135 mm
40 g
Transparent
Apple 13-inch iPad Air (M2, M3)
Intended For
Tablet
Protection
Package Content
Product Material
PET film (2H)
Coating
Anti-reflective
21.1 cm
27.66 cm
40 g
Thickness
0.135 mm
Transparent
Brand: Dicota
