Dicota Antimicrobial filter 2H for Apple iPad Air 11.0 2024, self-adhesive
Quicklinx: HV36WS00 Mfr#: D70834
£18.82 ex VAT
£22.58 inc VAT
The DICOTA protective film fulfils a variety of functions: it protects the display from scratches, reduces annoying fingerprints and is easy to attach. It also provides a non-reflective coating for high-resolution displays, guaranteeing a clear view. This makes the anti-glare film the number one choice for you. The film adheres directly to the full surface of the display thanks to the use of a silicone layer.
The anti-glare filters are made with the latest laser cutters and cut to the right size with maximum reliability. The filter is extremely easy to fit. It takes just a few seconds for it to adhere to the full surface of the display and begin carrying out its functions. No more scratches, fewer annoying fingerprints and a high degree of anti-reflection coating for your display. It can be easily removed at any time without leaving any residue. This is a quality German product you can rely on, and is simple and handy to use.
  • Durable construction
    Made from high-quality 2H PET film, this screen protector is designed to withstand daily wear and tear while maintaining the clarity of your screen.
  • Effective antimicrobial protection
    The antimicrobial filter actively reduces bacteria on the surface, providing an additional layer of hygiene for your device that is particularly useful for shared environments.
  • Scratch-resistant surface
    The scratch-resistant feature helps in keeping the tablet screen clear from unsightly marks and abrasions, enabling a longer lifespan for your device.
  • Clear visibility
    With an anti-reflective coating, the screen protector minimizes glare and reflections, making it easier to use your tablet in various lighting conditions.
  • Simple installation
    The self-adhesive design allows for straightforward installation, ensuring a bubble-free application that enhances your user experience right from the start.
DICOTA - screen protector for tablet - 2H, self-adhesive
Screen protector - film
Intended For
Tablet
Protection
Scratch-resistant, fingerprint-resistant, antimicrobial
Coating
Anti-reflective
Package Content
Screen protective film, cleaning wipe
Product Material
PET film (2H)
17.45 cm 24.36 cm
Thickness
0.135 mm
10 g
Transparent
Apple 11-inch iPad Air (M2, M3)
Intended For
Tablet
Protection
Package Content
Product Material
PET film (2H)
Coating
Anti-reflective
17.45 cm
24.36 cm
10 g
Thickness
0.135 mm
Transparent
Brand: Dicota
