Dicota Antibacterial Surface Cleaning Wipes Tub 50 pieces
Quicklinx: G0DTWS00 Mfr#: D31812
The cleaning wipes are ideal for fast and antibacterial cleaning of a wide range of different surfaces. Screens, touch screens, cameras, door handles or glasses are hygienically cleaned with only one application.
The wipes are free of alcohol and ammonia and allow cleaning without leaving streaks or scratches. The practical 50 piece dispenser box makes enable easy one-by-one use. The box is not only suitable for use in the workplace but can also be carried in a bag for use on the road. This way surfaces and objects can be cleaned of dirt and stains from everywhere.
DICOTA - cleaning wipes
Cleaning wipes
Packaged Quantity
50 pieces
Package Content
50 wet cleaning wipes
White
6.5 cm x 6.5 cm x 11.1 cm
110 g
Alcohol-free, ammonia-free, antibacterial, click-top
Packaged Quantity
50 pieces
Cleaning wipes
Package Content
6.5 cm
6.5 cm
11.1 cm
110 g
White
WEEE
Limited warranty: - 2 years
