The cleaning wipes are ideal for fast and antibacterial cleaning of a wide range of different surfaces. Screens, touch screens, cameras, door handles or glasses are hygienically cleaned with only one application.
The wipes are free of alcohol and ammonia and allow for clean cleaning without leaving streaks or scratches. No matter where the journey takes you, the disposable wipes are a practical companion. The wet wipes are packed in a compact 15 pcs. travel pack, which fits in any bag or backpack. So surfaces and objects can be cleaned from dirt and stains even when traveling. Thanks to the resealable sticker, the wipes remain moist and fresh between applications.
- DICOTA - cleaning wipes
- Product Type
- Cleaning wipes
- Packaged Quantity
- 15 pieces
- Package Content
- 15 wet cleaning wipes
- White
- 15.2 cm x 3 cm x 7.3 cm
- 40 g
- Alcohol-free, ammonia-free, antibacterial
- 2-year warranty
- Packaged Quantity
- 15 pieces
- Product Type
- Cleaning wipes
- Package Content
- 15.2 cm
- 3 cm
- 7.3 cm
- 40 g
- White
- WEEE
- Limited warranty: - 2 years
