Dicota Antibacterial Surface Cleaning Wipes Pack 15  pieces
Quicklinx: G0DRWS00 Mfr#: D31811
The cleaning wipes are ideal for fast and antibacterial cleaning of a wide range of different surfaces. Screens, touch screens, cameras, door handles or glasses are hygienically cleaned with only one application.
The wipes are free of alcohol and ammonia and allow for clean cleaning without leaving streaks or scratches. No matter where the journey takes you, the disposable wipes are a practical companion. The wet wipes are packed in a compact 15 pcs. travel pack, which fits in any bag or backpack. So surfaces and objects can be cleaned from dirt and stains even when traveling. Thanks to the resealable sticker, the wipes remain moist and fresh between applications.
DICOTA - cleaning wipes
Cleaning wipes
Packaged Quantity
15 pieces
Package Content
15 wet cleaning wipes
White
15.2 cm x 3 cm x 7.3 cm
40 g
Alcohol-free, ammonia-free, antibacterial
Packaged Quantity
15 pieces
Cleaning wipes
Package Content
15.2 cm
3 cm
7.3 cm
40 g
White
WEEE
Limited warranty: - 2 years
