Dicota Anti-microbiall filter 2H for DELL Latitude 7310 2-in1/7320 2-in1, self-adhesive
Quicklinx: GDT0WS00 Mfr#: D70399
£23.15 ex VAT
£27.78 inc VAT
The DICOTA antimicrobial film fulfils a variety of functions: it protects the display from scratches, reduces annoying fingerprints, minimises bacteria and is easy to attach. The film adheres directly to the full surface of the display thanks to the use of a silicone layer. The hardened coating on the filter provides long-term protection that continuously inhibits the growth of microbes over a long period of time.
The filters are made with the latest laser cutters and cut to the right size with maximum reliability. The filter is extremely easy to fit. It takes just a few seconds for it to adhere to the full surface of the display and begin carrying out its functions. No more scratches, bacteria, fewer annoying fingerprints and a high degree of anti-reflection coating for your display. It can be easily removed at any time without leaving any residue.
DICOTA - notebook anti-microbial filter
Notebook anti-microbial filter
Installation Type
Adhesive
Transparent
Product Material
PET
30.1 cm 18.7 cm
10 g
Anti-reflective, anti-scratch, easy-to-remove, antimicrobial finish, antibacterial, bubble-free installation, touch screen compatible, anti-mold, self-adhesive, fingerprint-proof, silicone layer back, 2H hard-coating, laser-cut edge, fungus-resistent
Dell Latitude 7310, 7310 2-in-1
Product Material
PET
30.1 cm
18.7 cm
Thickness
0.135 mm
10 g
Transparent
Display Filter
Installation Type
Adhesive
Scratch Resistant
Limited warranty: - 2 years
Brand: Dicota
