Dicota Anti-Glare Filter 9H For Vaio A12 Self-Adhesive
Quicklinx: FS9YWS00 Mfr#: D70140
The DICOTA protective film fulfils a variety of functions: it protects the display from scratches, reduces annoying fingerprints and is easy to attach. It also provides a non-reflective coating for high-resolution displays, guaranteeing a clear view. This makes the anti-glare film the number one choice for you. The film adheres directly to the full surface of the display thanks to the use of a silicone layer.
The anti-glare filters are made with the latest laser cutters and cut to the right size with maximum reliability. The filter is extremely easy to fit. It takes just a few seconds for it to adhere to the full surface of the display and begin carrying out its functions. No more scratches, fewer annoying fingerprints and a high degree of anti-reflection coating for your display. It can be easily removed at any time without leaving any residue. This is a quality German product you can rely on, and is simple and handy to use.
DICOTA - notebook anti-glare filter
Notebook anti-glare filter
Transparent
Product Material
PET
30.25 cm 19.65 cm
20 g
Self-adhesive, touch capable, 9H coating
Product Material
PET
30.25 cm
19.65 cm
Thickness
0.0205 cm
20 g
Transparent
Display Filter
Scratch Resistant
Limited warranty: - 2 years
