Dicota Anti-Glare filter 9H for Samsung Galaxy Xcover 6, self-adhesive
Quicklinx: HG29WS00 Mfr#: D70668
Product Range: DICOTA
£12.24 ex VAT
£14.68 inc VAT
The DICOTA protective film fulfils a variety of functions: it protects the display from scratches, reduces annoying fingerprints and is easy to attach. It also provides a non-reflective coating for high-resolution displays, guaranteeing a clear view. This makes the anti-glare film the number one choice for you. The film adheres directly to the full surface of the display thanks to the use of a silicone layer.
The anti-glare filters are made with the latest laser cutters and cut to the right size with maximum reliability. The filter is extremely easy to fit. It takes just a few seconds for it to adhere to the full surface of the display and begin carrying out its functions. No more scratches, fewer annoying fingerprints and a high degree of anti-reflection coating for your display. It can be easily removed at any time without leaving any residue. This is a quality German product you can rely on, and is simple and handy to use.
DICOTA - screen protector for mobile phone - 9H, self-adhesive
Screen protector - film
Intended For
Mobile phone
Protection
Anti-glare, anti-reflective, fingerprint-resistant, screen protection
Coating
Anti-reflective
Product Material
Silicone, polyethylene terephthalate (PET)
7.25 cm 16.15 cm
17 g
Intended For
Mobile phone
Protection
Product Material
Coating
Anti-reflective
7.25 cm
16.15 cm
17 g
2 years
Brand: Dicota
