The Dicota protective film fulfils a variety of functions: it protects the display from scratches, reduces annoying fingerprints and is easy to attach. It also provides a non-reflective coating for high-resolution displays, guaranteeing a clear view. This makes the anti-glare film the number one choice for you. The film adheres directly to the full surface of the display thanks to the use of a silicone layer.
The anti-glare filters are made with the latest laser cutters and cut to the right size with maximum reliability. The filter is extremely easy to fit. It takes just a few seconds for it to adhere to the full surface of the display and begin carrying out its functions. No more scratches, fewer annoying fingerprints and a high degree of anti-reflection coating for your display. It can be easily removed at any time without leaving any residue. This is a quality German product you can rely on, and is simple and handy to use.
- DICOTA - screen protector for mobile phone
- Product Type
- Screen protector - film
- Intended For
- Mobile phone
- Protection
- Scratch-resistant, fingerprint-proof, anti-glare
- Product Material
- PET film (9H)
- 7.16 cm 15.07 cm
- Thickness
- 0.015 mm
- 20 g
- Transparent
- 2-year warranty
- Designed For
- Samsung Galaxy A7 (2017)
- Product Type
- Intended For
- Mobile phone
- Protection
- Product Material
- PET film (9H)
- 7.16 cm
- 15.07 cm
- 20 g
- Thickness
- 0.015 mm
- Transparent
- 2-year warranty
- Designed For
