Dicota Anti-Glare filter 9H for Microsoft Surface Laptop Studio (2022), self-adhesive
Quicklinx: GX3XWS00 Mfr#: D70531
£28.73 ex VAT
£34.47 inc VAT
The DICOTA protective film fulfils a variety of functions: it protects the display from scratches, reduces annoying fingerprints and is easy to attach. It also provides a non-reflective coating for high-resolution displays, guaranteeing a clear view. This makes the anti-glare film the number one choice for you. The film adheres directly to the full surface of the display thanks to the use of a silicone layer.
The anti-glare filters are made with the latest laser cutters and cut to the right size with maximum reliability. The filter is extremely easy to fit. It takes just a few seconds for it to adhere to the full surface of the display and begin carrying out its functions. No more scratches, fewer annoying fingerprints and a high degree of anti-reflection coating for your display. It can be easily removed at any time without leaving any residue. This is a quality German product you can rely on, and is simple and handy to use.
  • Touch capable
  • Silicone layer on the back allows for full-surface adhesion
  • A clear view at all times
  • Accurate colour reproduction
  • Reduces reflections and fingerprints
  • High scratch resistance
  • Attaches easily without forming bubbles
  • No residue when removed
DICOTA - notebook anti-glare filter
Notebook anti-glare filter
Installation Type
Adhesive
Transparent
Product Material
PET
31.8 cm 21.7 cm
20 g
Anti-reflective, anti-scratch, easy-to-remove, bubble-free installation, self-adhesive, fingerprint-proof, silicone layer back, touch capable, 9H coating
Microsoft Surface Laptop Studio (14.4 in)
Product Material
PET
31.8 cm
21.7 cm
Thickness
0.205 mm
20 g
Transparent
Display Filter
Installation Type
Adhesive
Scratch Resistant
Frameless
Limited warranty: - 2 years
Brand: Dicota
