The DICOTA protective film fulfils a variety of functions: it protects the display from scratches, reduces annoying fingerprints and is easy to attach. It also provides a non-reflective coating for high-resolution displays, guaranteeing a clear view. This makes the anti-glare film the number one choice for you. The film adheres directly to the full surface of the display thanks to the use of a silicone layer.
The anti-glare filters are made with the latest laser cutters and cut to the right size with maximum reliability. The filter is extremely easy to fit. It takes just a few seconds for it to adhere to the full surface of the display and begin carrying out its functions. No more scratches, fewer annoying fingerprints and a high degree of anti-reflection coating for your display. It can be easily removed at any time without leaving any residue. This is a quality German product you can rely on, and is simple and handy to use.
Touch capable
Silicone layer on the back allows for full-surface adhesion
A clear view at all times
Accurate colour reproduction
Reduces reflections and fingerprints
High scratch resistance
Attaches easily without forming bubbles
No residue when removed.
Enhanced durability
Equipped with a 9H coating, this notebook anti-glare filter offers exceptional scratch resistance, ensuring your screen remains pristine even under frequent use. -
Optimal viewing
The anti-glare feature combined with accurate color reproduction and a clear view ensures an optimal viewing experience, reducing eye strain and enhancing productivity. -
User-friendly design
Featuring an easy-to-remove silicone layer back, this filter is designed for hassle-free application and removal, leaving no residue and maintaining the integrity of your screen.
- DICOTA - notebook anti-glare filter - 9H
- Product Type
- Notebook anti-glare filter - 9H
- Installation Type
- Removable - adhesive
- Product Material
- PET
- 27.3 cm 19.5 cm
- 20 g
- Display Screen Size Compatibility
- 12.4"
- Anti-glare, easy-to-remove, silicone layer back, touch capable, 9H coating, clear view, accurate colour reproduction, residue free
- 2-year warranty
- Designed For
- Microsoft Surface Laptop Go
- Product Type
- Product Material
- PET
- 27.3 cm
- 19.5 cm
- Thickness
- 0.205 mm
- 20 g
- 12.4"
Display Filter
- Installation Type
- Scratch Resistant
- Limited warranty: - 2 years
- Designed For
