Dicota Anti-glare filter 9H for Microsoft Surface Laptop 5 15.0, self-adhesive
Quicklinx: HG33WS00 Mfr#: D70684
£34.42 ex VAT
£41.30 inc VAT
The DICOTA protective film fulfils a variety of functions: it protects the display from scratches, reduces annoying fingerprints and is easy to attach. It also provides a non-reflective coating for high-resolution displays, guaranteeing a clear view. This makes the anti-glare film the number one choice for you. The film adheres directly to the full surface of the display thanks to the use of a silicone layer.
The anti-glare filters are made with the latest laser cutters and cut to the right size with maximum reliability. The filter is extremely easy to fit. It takes just a few seconds for it to adhere to the full surface of the display and begin carrying out its functions. No more scratches, fewer annoying fingerprints and a high degree of anti-reflection coating for your display. It can be easily removed at any time without leaving any residue. This is a quality German product you can rely on, and is simple and handy to use.
Touch capable
Silicone layer on the back allows for full-surface adhesion
A clear view at all times
Accurate colour reproduction
Reduces reflections and fingerprints
High scratch resistance
Attaches easily without forming bubbles
No residue when removed.
  • Enhanced durability
    Crafted from high-quality PET material, this monitor protective film is designed to withstand daily wear and tear, ensuring your device remains in pristine condition.
  • Optimal clarity
    Featuring an anti-reflective and anti-glare design, the film provides exceptional screen clarity under various lighting conditions, enhancing your viewing experience.
  • Touch compatibility
    Engineered to be fully compatible with touch screens, this protective film maintains the responsiveness and sensitivity of your device's screen, ensuring seamless use.
  • Fingerprint and scratch resistance
    The film's fingerprint-proof and scratch-resistant features keep your screen clean and clear, minimizing distractions and maintaining the aesthetic appeal of your device.
DICOTA - monitor protective film - 9H, anti-reflective, self-adhesive
Monitor protective film - 9H, anti-reflective, self-adhesive
Product Material
PET
33.7 cm 23.4 cm
20 g
Anti-glare, anti-reflective, touch screen compatible, scratch-resistant, adhesive mount, fingerprint-proof
Product Material
PET
33.7 cm
23.4 cm
Thickness
0.25 mm
20 g
Limited warranty: - 2 years
Brand: Dicota
