Dicota Anti-Glare Filter 9H For Microsoft Surface Laptop 3 13.5" Self-Adhesive
Quicklinx: FS9PWS00 Mfr#: D70290
£23.48 ex VAT
£28.17 inc VAT
The DICOTA protective film fulfils a variety of functions: it protects the display from scratches, reduces annoying fingerprints and is easy to attach. It also provides a non-reflective coating for high-resolution displays, guaranteeing a clear view. This makes the anti-glare film the number one choice for you. The film adheres directly to the full surface of the display thanks to the use of a silicone layer.
The anti-glare filters are made with the latest laser cutters and cut to the right size with maximum reliability. The filter is extremely easy to fit. It takes just a few seconds for it to adhere to the full surface of the display and begin carrying out its functions. No more scratches, fewer annoying fingerprints and a high degree of anti-reflection coating for your display. It can be easily removed at any time without leaving any residue.
DICOTA Anti-Glare Filter 9H - notebook anti-glare filter
Notebook anti-glare filter
Transparent
Product Material
PET
30.4 cm 21.3 cm
20 g
Display Screen Size Compatibility
13.5"
Anti-reflective, fingerprint-resistant coating, self-adhesive, silicone layer back, high mechanical resilience, touch capable
Microsoft Surface Laptop 3 (13.5 in)
Product Material
PET
30.4 cm
21.3 cm
Thickness
0.205 mm
20 g
13.5"
Transparent
Display Filter
Scratch Resistant
Limited warranty: - 2 years
Brand: Dicota
