Dicota Anti-Glare Filter 9H For MacBook Pro 16" Retina (2019) Self-Adhesive
Quicklinx: FS9MWS00 Mfr#: D70278
£27.65 ex VAT
£33.18 inc VAT
The DICOTA protective film fulfils a variety of functions: it protects the display from scratches, reduces annoying fingerprints and is easy to attach. It also provides a non-reflective coating for high-resolution displays, guaranteeing a clear view. This makes the anti-glare film the number one choice for you. The film adheres directly to the full surface of the display thanks to the use of a silicone layer.
DICOTA - notebook anti-glare filter
Notebook anti-glare filter
Transparent
Product Material
PET
35.4 cm 22.9 cm
30 g
Display Screen Size Compatibility
16"
Anti-reflective, fingerprint-resistant coating, self-adhesive, touch capable, 9H coating
Apple MacBook Pro (16 in)
Product Material
PET
35.4 cm
22.9 cm
Thickness
0.205 mm
30 g
16"
Transparent
Limited warranty: - 2 years
Brand: Dicota
