The DICOTA protective film fulfils a variety of functions: it protects the display from scratches, reduces annoying fingerprints and is easy to attach. It also provides a non-reflective coating for high-resolution displays, guaranteeing a clear view. This makes the anti-glare film the number one choice for you. The film adheres directly to the full surface of the display thanks to the use of a silicone layer.
The anti-glare filters are made with the latest laser cutters and cut to the right size with maximum reliability. The filter is extremely easy to fit. It takes just a few seconds for it to adhere to the full surface of the display and begin carrying out its functions. No more scratches, fewer annoying fingerprints and a high degree of anti-reflection coating for your display. It can be easily removed at any time without leaving any residue. This is a quality German product you can rely on, and is simple and handy to use.
Touch capable
Silicone layer on the back allows for full-surface adhesion
A clear view at all times
Accurate colour reproduction
Reduces reflections and fingerprints
High scratch resistance
Attaches easily without forming bubbles
No residue when removed.
Enhanced durability
Crafted from PET film with a 9H hardness rating, this screen protector offers protection against scratches and impacts, ensuring your cellular phone's screen remains in pristine condition. -
Superior clarity
The anti-reflective film design minimizes glare and reflection, providing clear visibility even in bright conditions. Its anti-glare properties enhance the viewing experience, making it easier to see your screen without straining your eyes. -
Fingerprint resistance
Thanks to its fingerprint-resistant coating, the screen protector keeps your display clean and smudge-free. This feature ensures that your screen looks clear and readable at all times, enhancing your device's aesthetic and functional appeal.
- DICOTA - screen protector for mobile phone - 9H, self-adhesive
- Product Type
- Screen protector - film
- Intended For
- Mobile phone
- Protection
- Scratch-resistant, anti-glare, anti-reflective, fingerprint-resistant
- Product Material
- PET film (9H)
- 7.29 cm 15.6 cm
- Thickness
- 0.2 mm
- 2-year warranty
- Designed For
- Apple iPhone 15 Pro Max
- Product Type
- Intended For
- Mobile phone
- Protection
- Product Material
- PET film (9H)
- 7.29 cm
- 15.6 cm
- Thickness
- 0.2 mm
- 2 years
- Designed For
