Dicota Anti-Glare Filter 9H For iPhone 11 Pro Self-Adhesive
Quicklinx: FS9FWS00 Mfr#: D70204
Product Range: DICOTA
Product Model: Anti-Glare Filter 9H
£9.21 ex VAT
£11.05 inc VAT
The Dicota protective film fulfils a variety of functions: it protects the display from scratches, reduces annoying fingerprints and is easy to attach. It also provides a non-reflective coating for high-resolution displays, guaranteeing a clear view. This makes the anti-glare film the number one choice for you. The film adheres directly to the full surface of the display thanks to the use of a silicone layer.
The anti-glare filters are made with the latest laser cutters and cut to the right size with maximum reliability. The filter is extremely easy to fit. It takes just a few seconds for it to adhere to the full surface of the display and begin carrying out its functions. No more scratches, fewer annoying fingerprints and a high degree of anti-reflection coating for your display. It can be easily removed at any time without leaving any residue. This is a quality German product you can rely on, and is simple and handy to use.
DICOTA - screen protector for mobile phone
Screen protector - film
Intended For
Mobile phone
Protection
Scratch-resistant, fingerprint-proof, anti-glare
Product Material
PET film (9H)
6.233 cm 13.495 cm
Thickness
0.205 mm
3 g
Transparent
Apple iPhone 11 Pro
Intended For
Mobile phone
Protection
Product Material
PET film (9H)
6.233 cm
13.495 cm
3 g
Thickness
0.205 mm
Transparent
Apple iPhone 11 Pro
Brand: Dicota
