Dicota Anti-Glare Filter 9H For iPad Pro 11" (2018) Self-Adhesive
Quicklinx: FS9BWS00 Mfr#: D70096
£13.62 ex VAT
£16.34 inc VAT
The Dicota protective film fulfils a variety of functions: it protects the display from scratches, reduces annoying fingerprints and is easy to attach. It also provides a non-reflective coating for high-resolution displays, guaranteeing a clear view. This makes the anti-glare film the number one choice for you. The film adheres directly to the full surface of the display thanks to the use of a silicone layer.
The anti-glare filters are made with the latest laser cutters and cut to the right size with maximum reliability. The filter is extremely easy to fit. It takes just a few seconds for it to adhere to the full surface of the display and begin carrying out its functions. No more scratches, fewer annoying fingerprints and a high degree of anti-reflection coating for your display. It can be easily removed at any time without leaving any residue. This is a quality German product you can rely on, and is simple and handy to use.
DICOTA - screen protector for tablet
Screen protector - film
Intended For
Tablet
Screen Size Compatibility
11"
Protection
Scratch-resistant, fingerprint-proof, anti-glare
Product Material
PET film (9H)
24.3 cm 17.4 cm
Thickness
0.15 mm
10 g
Transparent
Apple 11-inch iPad Pro (1st generation)
Intended For
Tablet
11"
Protection
Product Material
PET film (9H)
24.3 cm
17.4 cm
10 g
Thickness
0.15 mm
Transparent
Brand: Dicota
