Dicota Anti-glare filter 9H for iMac 24 (2021), self-adhesive
Quicklinx: HG2KWS00 Mfr#: D70656
£69.96 ex VAT
£83.95 inc VAT
The DICOTA protective film fulfils a variety of functions: it protects the display from scratches, reduces annoying fingerprints and is easy to attach. It also provides a non-reflective coating for high-resolution displays, guaranteeing a clear view. This makes the anti-glare film the number one choice for you. The film adheres directly to the full surface of the display thanks to the use of a silicone layer.
The anti-glare filters are made with the latest laser cutters and cut to the right size with maximum reliability. The filter is extremely easy to fit. It takes just a few seconds for it to adhere to the full surface of the display and begin carrying out its functions. No more scratches, fewer annoying fingerprints and a high degree of anti-reflection coating for your display. It can be easily removed at any time without leaving any residue. This is a quality German product you can rely on, and is simple and handy to use.
DICOTA - display anti-glare filter - 9H
Display anti-glare filter - 9H
Installation Type
Adhesive
Image Colour Disclaimer
The displayed product image may be a different colour
Product Material
PET
54.15 cm 31.55 cm
50 g
Anti-reflective, fingerprint-resistant coating, bubble-free installation, silicone layer back, touch capable, 9H coating, clear view, accurate colour reproduction, residue free
Apple iMac (24 in)
Product Material
PET
54.15 cm
31.55 cm
Thickness
0.205 mm
50 g
Finish
Matte
Display Filter
Installation Type
Adhesive
Scratch Resistant
Limited warranty: - 2 years
Apple iMac (24 in)
Brand: Dicota
