Dicota Anti-glare filter 9H for HP Elite x360 1040 G9, self-adhesive
Quicklinx: HG5KWS00 Mfr#: D70598
£28.73 ex VAT
£34.47 inc VAT
The DICOTA protective film fulfils a variety of functions: it protects the display from scratches, reduces annoying fingerprints and is easy to attach. It also provides a non-reflective coating for high-resolution displays, guaranteeing a clear view. This makes the anti-glare film the number one choice for you. The film adheres directly to the full surface of the display thanks to the use of a silicone layer.
The anti-glare filters are made with the latest laser cutters and cut to the right size with maximum reliability. The filter is extremely easy to fit. It takes just a few seconds for it to adhere to the full surface of the display and begin carrying out its functions. No more scratches, fewer annoying fingerprints and a high degree of anti-reflection coating for your display. It can be easily removed at any time without leaving any residue. This is a quality German product you can rely on, and is simple and handy to use.
DICOTA - notebook anti-glare filter - 9H
Notebook anti-glare filter - 9H
Installation Type
Removable - adhesive
Product Material
PET film (9H)
30.9 cm 21.28 cm
20 g
Anti-glare, anti-reflective, fingerprint-resistant coating, bubble-free installation, self-adhesive, silicone layer back, touch capable, clear view, accurate colour reproduction, residue free
Product Material
PET film (9H)
30.9 cm
21.28 cm
Thickness
0.2 mm
20 g
Display Filter
Installation Type
Scratch Resistant
Limited warranty: - 2 years
Brand: Dicota
