Dicota Anti-Glare Filter 9H For HP Elite X2 G4 Self-Adhesive
Quicklinx: FS97WS00 Mfr#: D70212
£17.95 ex VAT
£21.54 inc VAT
The DICOTA protective film fulfils a variety of functions: it protects the display from scratches, reduces annoying fingerprints and is easy to attach. It also provides a non-reflective coating for high-resolution displays, guaranteeing a clear view. This makes the anti-glare film the number one choice for you. The film adheres directly to the full surface of the display thanks to the use of a silicone layer.
The anti-glare filters are made with the latest laser cutters and cut to the right size with maximum reliability. The filter is extremely easy to fit. It takes just a few seconds for it to adhere to the full surface of the display and begin carrying out its functions. No more scratches, fewer annoying fingerprints and a high degree of anti-reflection coating for your display. It can be easily removed at any time without leaving any residue.
  • Enhanced screen protection
    The DICOTA Anti-Glare Filter 9H is made from high-quality PET material, offering protection against scratches and impacts. Its durable construction ensures your notebook or tablet PC's screen stays in excellent condition, safeguarding your device.
  • Improved viewing experience
    This anti-glare filter significantly reduces screen glare, making it easier to view your display in brightly lit environments. By minimizing eye strain, it improves your working comfort and productivity, whether you're indoors or outdoors.
DICOTA Anti-Glare Filter 9H - notebook anti-glare filter
Notebook anti-glare filter
Transparent
Product Material
PET
28.35 cm 20.95 cm
20 g
Anti-glare, anti-reflective, fingerprint-resistant coating, self-adhesive, silicone layer back, high mechanical resilience, touch capable
HP Elite x2 G4
Product Material
PET
28.35 cm
20.95 cm
Thickness
0.205 mm
20 g
Transparent
Display Filter
Scratch Resistant
Limited warranty: - 2 years
HP Elite x2 G4
Brand: Dicota
