Dicota Anti-Glare filter 9H for DELL XPS 13 (9315) 2in1, self-adhesive
Quicklinx: HG5HWS00 Mfr#: D70601
£25.39 ex VAT
£30.46 inc VAT
The DICOTA protective film fulfills a variety of functions: it protects the display from scratches, reduces annoying fingerprints and is easy to attach. It also provides a non-reflective coating for high-resolution displays, guaranteeing a clear view. This makes the anti-glare film the number one choice for you. The film adheres directly to the full surface of the display thanks to the use of a silicone layer.
The anti-glare filters are made with advanced laser cutters and cut to the right size with maximum reliability. The filter is extremely easy to fit. It takes just a few seconds for it to adhere to the full surface of the display and begin carrying out its functions. No more scratches, fewer annoying fingerprints and a high degree of anti-reflection coating for your display. It can be easily removed at any time without leaving any residue. This is a quality product you can rely on, and is simple and handy to use.
DICOTA - notebook anti-glare filter - 9H
Notebook anti-glare filter - 9H
Installation Type
Removable - adhesive
Product Material
PET
28.9 cm 19.8 cm
17 g
Display Screen Size Compatibility
13"
Fingerprint-resistant coating, bubble-free installation, silicone layer back, touch capable, clear view, accurate colour reproduction, anti-reflection coating
Dell XPS 13
Product Material
PET
28.9 cm
19.8 cm
Thickness
0.2 mm
17 g
13"
Display Filter
Installation Type
Scratch Resistant
Limited warranty: - 2 years
Dell XPS 13
Brand: Dicota
