Dicota Anti-glare filter 9H for Dell U2722DE, self-adhesive
Quicklinx: HG2MWS00 Mfr#: D70618
£85.45 ex VAT
£102.54 inc VAT
The DICOTA protective film fulfills a variety of functions: it protects the display from scratches, reduces annoying fingerprints and is easy to attach. It also provides a non-reflective coating for high-resolution displays, guaranteeing a clear view. This makes the anti-glare film the number one choice for you. The film adheres directly to the full surface of the display thanks to the use of a silicone layer.
The anti-glare filters are made with advanced laser cutters and cut to the right size with maximum reliability. The filter is extremely easy to fit. It takes just a few seconds for it to adhere to the full surface of the display and begin carrying out its functions. No more scratches, fewer annoying fingerprints and a high degree of anti-reflection coating for your display. It can be easily removed at any time without leaving any residue. This is a quality product you can rely on, and is simple and handy to use.
DICOTA display anti-glare filter - 9H
Display anti-glare filter
Installation Type
Adhesive
Product Material
PET
60.83 cm 34.15 cm
82 g
Dell UltraSharp U2722DE
Product Material
PET
60.83 cm 34.15 cm
82 g
Display Filter
Installation Type
Adhesive
Surface Finish
Matte
Scratch Resistant
Anti-reflective, fingerprint-resistant coating, bubble-free installation, silicone layer back, touch capable, clear view, accurate colour reproduction
Brand: Dicota
