Dicota Anti-Glare filter 9H for DELL Latitude 7310 2-in1/7320 2-in1, self-adhesive
Quicklinx: GDSWWS00 Mfr#: D70398
£24.15 ex VAT
£28.98 inc VAT
The DICOTA protective film fulfils a variety of functions: it protects the display from scratches, reduces annoying fingerprints and is easy to attach. It also provides a non-reflective coating for high-resolution displays, guaranteeing a clear view. This makes the anti-glare film the number one choice for you. The film adheres directly to the full surface of the display thanks to the use of a silicone layer.
The anti-glare filters are made with the latest laser cutters and cut to the right size with maximum reliability. The filter is extremely easy to fit. It takes just a few seconds for it to adhere to the full surface of the display and begin carrying out its functions. No more scratches, fewer annoying fingerprints and a high degree of anti-reflection coating for your display. It can be easily removed at any time without leaving any residue.
DICOTA - notebook anti-glare filter
Notebook anti-glare filter
Installation Type
Adhesive
Transparent
Product Material
PET
30.1 cm 18.7 cm
20 g
Anti-glare, anti-reflective, anti-scratch, easy-to-remove, bubble-free installation, touch screen compatible, fingerprint-proof, silicone layer back, high mechanical resilience, 9H coating, laser-cut edge
Dell Latitude 7310 2-in-1, 7320 2-in-1
Product Material
PET
30.1 cm
18.7 cm
Thickness
0.205 mm
20 g
Transparent
Display Filter
Installation Type
Adhesive
Scratch Resistant
Limited warranty: - 2 years
Brand: Dicota
