Dicota Anti-glare filter 9H for 55.88cm 22.0 Wide (16:10), self-adhesive
Quicklinx: HH64WS00 Mfr#: D70731
£57.34 ex VAT
£68.80 inc VAT
The DICOTA protective film fulfils a variety of functions: it protects the display from scratches, reduces annoying fingerprints and is easy to attach. It also provides a non-reflective coating for high-resolution displays, guaranteeing a clear view. This makes the anti-glare film the number one choice for you. The film adheres directly to the full surface of the display thanks to the use of a silicone layer.
The anti-glare filters are made with the latest laser cutters and cut to the right size with maximum reliability. The filter is extremely easy to fit. It takes just a few seconds for it to adhere to the full surface of the display and begin carrying out its functions. No more scratches, fewer annoying fingerprints and a high degree of anti-reflection coating for your display. It can be easily removed at any time without leaving any residue. This is a quality German product you can rely on, and is simple and handy to use.
Touch capable
Silicone layer on the back allows for full-surface adhesion
A clear view at all times
Accurate colour reproduction
Reduces reflections and fingerprints
High scratch resistance
Attaches easily without forming bubbles
No residue when removed.
  • Enhanced durability
    Equipped with a 9H coating, this display anti-glare filter offers exceptional scratch resistance, ensuring your screen remains pristine over time.
  • Optimal viewing
    The anti-reflective and accurate color reproduction features provide a clear view and vibrant visuals, making it suitable for both work and entertainment.
  • User-friendly design
    Thanks to its bubble-free installation and easy-to-remove silicone layer back, setting up this filter is a straightforward process, ensuring a smooth, residue-free removal when needed.
DICOTA - display anti-glare filter - 9H, 16:10 / 55.88 cm
Display anti-glare filter - 9H, 16:10 / 55.88 cm
Installation Type
Adhesive
Image Colour Disclaimer
The displayed product image may be a different colour
Product Material
PET
47.4 cm 29.7 cm
40 g
Display Screen Size Compatibility
22"
Anti-reflective, easy-to-remove, fingerprint-resistant coating, bubble-free installation, silicone layer back, touch capable, 9H coating, clear view, accurate colour reproduction, residue free
Product Material
PET
47.4 cm
29.7 cm
Thickness
0.25 mm
40 g
22"
Display Filter
Installation Type
Adhesive
Scratch Resistant
Limited warranty: - 2 years
Brand: Dicota
