The DICOTA screen protector takes care of various tasks: it protects the screen against scratches, reduces annoying fingerprint marks and is easy to attach. In addition, the high-resolution screen becomes anti-reflective, ensuring clear visibility. The screen protector is your first choice. The filter reduces reflections caused by sunlight and protects the screen from scratches. The film adheres directly to the screen thanks to the use of a silicon layer.
- DICOTA - notebook anti-glare filter
- Product Type
- Notebook anti-glare filter
- Product Material
- PET
- 28.7 cm 19.7 cm
- 14 g
- Self-adhesive
- 2-year warranty
- Designed For
- Microsoft Surface Pro (Mid 2017)
- Product Type
- Product Material
- PET
- 28.7 cm
- 19.7 cm
- Thickness
- 1 mm
- 14 g
Display Filter
- Scratch Resistant
- Self-adhesive
- Limited warranty: - 2 years
- Designed For
