The anti-glare filters reduce reflections caused by sunlight and protect the screen from scratches. The DICOTA protective film fulfils a variety of functions: it protects the display from scratches, reduces annoying fingerprints and is easy to attach. It also provides a non-reflective coating for high-resolution displays, guaranteeing a clear view. This makes the anti-glare film the number one choice for you. The film adheres directly to the full surface of the display thanks to the use of a silicone layer.
The anti-glare filters are made with the latest laser cutters and cut to the right size with maximum reliability. The filter is extremely easy to fit. It takes just a few seconds for it to adhere to the full surface of the display and begin carrying out its functions. No more scratches, fewer annoying fingerprints and a high degree of anti-reflection coating for your display. It can be easily removed at any time without leaving any residue.
- DICOTA Anti-Glare Filter 3H - display anti-glare filter
- Product Type
- Display anti-glare filter
- Transparent
- Product Material
- PET
- 30.4 cm 21.23 cm
- 20 g
- Anti-glare, anti-reflective, fingerprint-resistant coating, mechanical splices, bubble-free installation, self-adhesive
- 2-year warranty
- Designed For
- Microsoft Surface Laptop, Laptop 2
- Product Type
- Product Material
- PET
- 30.4 cm
- 21.23 cm
- Thickness
- 0.155 mm
- 20 g
- Transparent
- Limited warranty: - 2 years
- Designed For
