Dicota Anti-Glare Filter 3H For Surface Laptop/Laptop 2 Self-Adhesive
Quicklinx: FS8SWS00 Mfr#: D70105
£21.05 ex VAT
£25.26 inc VAT
The anti-glare filters reduce reflections caused by sunlight and protect the screen from scratches. The DICOTA protective film fulfils a variety of functions: it protects the display from scratches, reduces annoying fingerprints and is easy to attach. It also provides a non-reflective coating for high-resolution displays, guaranteeing a clear view. This makes the anti-glare film the number one choice for you. The film adheres directly to the full surface of the display thanks to the use of a silicone layer.
The anti-glare filters are made with the latest laser cutters and cut to the right size with maximum reliability. The filter is extremely easy to fit. It takes just a few seconds for it to adhere to the full surface of the display and begin carrying out its functions. No more scratches, fewer annoying fingerprints and a high degree of anti-reflection coating for your display. It can be easily removed at any time without leaving any residue.
  • Enhanced screen protection
    The Anti-Glare Filter 3H by DICOTA is crafted from high-quality PET material, offering durable protection against scratches and damage to your notebook or tablet PC's screen.
  • Improved viewing experience
    Designed to minimize glare and reflections, this filter enhances your device's display readability in various lighting conditions, making it ideal for both indoor and outdoor use.
DICOTA Anti-Glare Filter 3H - display anti-glare filter
Display anti-glare filter
Transparent
Product Material
PET
30.4 cm 21.23 cm
20 g
Anti-glare, anti-reflective, fingerprint-resistant coating, mechanical splices, bubble-free installation, self-adhesive
Microsoft Surface Laptop, Laptop 2
Product Material
PET
30.4 cm
21.23 cm
Thickness
0.155 mm
20 g
Transparent
Limited warranty: - 2 years
Brand: Dicota
