Dicota Anti-glare filter 3H for Samsung Galaxy A50, self-adhesive
Quicklinx: HH6KWS00 Mfr#: D70735
Product Range: DICOTA
£9.21 ex VAT
£11.05 inc VAT
The DICOTA protective film fulfils a variety of functions: it protects the display from scratches, reduces annoying fingerprints and is easy to attach. It also provides a non-reflective coating for high-resolution displays, guaranteeing a clear view. This makes the anti-glare film the number one choice for you. The film adheres directly to the full surface of the display thanks to the use of a silicone layer.
The anti-glare filters are made with the latest laser cutters and cut to the right size with maximum reliability. The filter is extremely easy to fit. It takes just a few seconds for it to adhere to the full surface of the display and begin carrying out its functions. No more scratches, fewer annoying fingerprints and a high degree of anti-reflection coating for your display. It can be easily removed at any time without leaving any residue. This is a quality German product you can rely on, and is simple and handy to use.
Touch capable
Silicone layer on the back allows for full-surface adhesion
A clear view at all times
Accurate colour reproduction
Reduces reflections and fingerprints
High scratch resistance
Attaches easily without forming bubbles
No residue when removed.
  • Enhanced visibility
    The anti-glare and anti-reflective features of this screen protector ensure your cellular phone's display remains visible and clear, even under bright lighting conditions. By reducing glare and reflections, it enhances the viewing experience for the user.
  • Durable protection
    Crafted from high-quality PET film with a 3H hardness rating, this screen protector offers robust protection against scratches and fingerprints. Its durability ensures your device's screen stays pristine, maintaining its aesthetic appeal and functionality over time.
DICOTA - screen protector for mobile phone - 3H, self-adhesive
Screen protector - film
Intended For
Mobile phone
Protection
Scratch-resistant, anti-glare, anti-reflective, fingerprint-resistant
Product Material
PET film (3H)
7.2 cm 15.5 cm
Thickness
0.23 mm
Transparent
Samsung Galaxy A50
Intended For
Mobile phone
Protection
Product Material
PET film (3H)
7.2 cm
15.5 cm
Thickness
0.23 mm
Transparent
2 years
Samsung Galaxy A50
Brand: Dicota
