Dicota Anti-Glare Filter 3H For Monitor 23.8 Wide (16:9) Self-Adhesive
Quicklinx: FS80WS00 Mfr#: D31314
£41.59 ex VAT
£49.90 inc VAT
The DICOTA protective film fulfils a variety of functions: it protects the display from scratches, reduces annoying fingerprints and is easy to attach. It also provides a non-reflective coating for high-resolution displays, guaranteeing a clear view. This makes the anti-glare film the number one choice for you. The film adheres directly to the full surface of the display thanks to the use of a silicone layer.
The anti-glare filters are made with the latest laser cutters and cut to the right size with maximum reliability. The filter is extremely easy to fit. It takes just a few seconds for it to adhere to the full surface of the display and begin carrying out its functions. No more scratches, fewer annoying fingerprints and a high degree of anti-reflection coating for your display. It can be easily removed at any time without leaving any residue. This is a quality German product you can rely on, and is simple and handy to use.
DICOTA - display anti-glare filter
Display anti-glare filter
Transparent
Product Material
PET
52.7 cm 29.6 cm
40 g
Display Screen Size Compatibility
23.8"
Easy-to-remove, bubble-free installation, touch screen compatible, self-adhesive, fingerprint-proof, silicone layer back
Product Material
PET
52.7 cm
29.6 cm
Thickness
0.15 mm
40 g
23.8"
Transparent
Display Filter
Aspect Ratio
16:9
Scratch Resistant
Brand: Dicota
