Dicota Anti-Glare Filter 3H For Microsoft Surface Pro X Self-Adhesive
Quicklinx: FS7VWS00 Mfr#: D70283
£18.58 ex VAT
£22.29 inc VAT
The anti-glare filters reduce reflections caused by sunlight and protect the screen from scratches. The DICOTA protective film fulfils a variety of functions: it protects the display from scratches, reduces annoying fingerprints and is easy to attach. It also provides a non-reflective coating for high-resolution displays, guaranteeing a clear view. This makes the anti-glare film the number one choice for you. The film adheres directly to the full surface of the display thanks to the use of a silicone layer.
The anti-glare filters are made with the latest laser cutters and cut to the right size with maximum reliability. The filter is extremely easy to fit. It takes just a few seconds for it to adhere to the full surface of the display and begin carrying out its functions. No more scratches, fewer annoying fingerprints and a high degree of anti-reflection coating for your display. It can be easily removed at any time without leaving any residue.
DICOTA Anti-Glare Filter 3H - notebook anti-glare filter
Notebook anti-glare filter
Transparent
Product Material
PET
28.12 cm 20.29 cm
10 g
Anti-glare, anti-reflective, fingerprint-resistant coating, self-adhesive, silicone layer back, high mechanical resilience, touch capable
Product Material
PET
28.12 cm
20.29 cm
Thickness
0.155 mm
10 g
Transparent
Display Filter
Scratch Resistant
Limited warranty: - 2 years
Brand: Dicota
