Dicota Anti-glare filter 3H for Microsoft Surface Laptop 5 15.0, self-adhesive
Quicklinx: HG31WS00 Mfr#: D70683
£25.26 ex VAT
£30.31 inc VAT
The DICOTA protective film fulfills a variety of functions: it protects the display from scratches, reduces annoying fingerprints and is easy to attach. It also provides a non-reflective coating for high-resolution displays, guaranteeing a clear view. This makes the anti-glare film the better choice for you. The film adheres directly to the full surface of the display thanks to the use of a silicone layer.
The anti-glare filters are made with the laser cutters and cut to the right size with maximum reliability. The filter is extremely easy to fit. It takes just a few seconds for it to adhere to the full surface of the display and begin carrying out its functions. No more scratches, fewer annoying fingerprints and a high degree of anti-reflection coating for your display. It can be easily removed at any time without leaving any residue. This is a quality German product you can rely on, and is simple and handy to use.
DICOTA - notebook anti-glare filter - 3H, anti-reflection, self-adhesive
Notebook anti-glare filter - 3H, anti-reflection, self-adhesive
Installation Type
Adhesive
Image Colour Disclaimer
The displayed product image may be a different colour
Product Material
PET
33.7 cm 23.35 cm
20 g
Display Screen Size Compatibility
15"
Anti-glare, anti-reflective, bubble-free installation, fingerprint-proof, silicone layer back, clear view
Product Material
PET
33.7 cm
23.35 cm
20 g
15"
Display Filter
Installation Type
Adhesive
Scratch Resistant
Limited warranty: - 2 years
Brand: Dicota
