The DICOTA protective film fulfils a variety of functions: it protects the display from scratches, reduces annoying fingerprints and is easy to attach. It also provides a non-reflective coating for high-resolution displays, guaranteeing a clear view. This makes the anti-glare film the number one choice for you. The film adheres directly to the full surface of the display thanks to the use of a silicone layer.
- DICOTA - notebook anti-glare filter
- Product Type
- Notebook anti-glare filter
- Transparent
- Product Material
- PET
- 35.4 cm 22.9 cm
- 20 g
- Display Screen Size Compatibility
- 16"
- Anti-reflective, fingerprint-resistant coating, 3H hard-coating, self-adhesive, touch capable
- 2-year warranty
- Designed For
- Apple MacBook Pro (16 in)
- Product Type
- Product Material
- PET
- 35.4 cm
- 22.9 cm
- Thickness
- 0.0155 cm
- 20 g
- 16"
- Transparent
- Limited warranty: - 2 years
- Designed For
