Dicota Anti-Glare Filter 3H For MacBook Pro 16 Retina (2019) Self-Adhesive
Quicklinx: FS7PWS00 Mfr#: D70277
£26.40 ex VAT
£31.68 inc VAT
The DICOTA protective film fulfils a variety of functions: it protects the display from scratches, reduces annoying fingerprints and is easy to attach. It also provides a non-reflective coating for high-resolution displays, guaranteeing a clear view. This makes the anti-glare film the number one choice for you. The film adheres directly to the full surface of the display thanks to the use of a silicone layer.
DICOTA - notebook anti-glare filter
Notebook anti-glare filter
Transparent
Product Material
PET
35.4 cm 22.9 cm
20 g
Display Screen Size Compatibility
16"
Anti-reflective, fingerprint-resistant coating, 3H hard-coating, self-adhesive, touch capable
Apple MacBook Pro (16 in)
Product Material
PET
35.4 cm
22.9 cm
Thickness
0.0155 cm
20 g
16"
Transparent
Limited warranty: - 2 years
Brand: Dicota
