Dicota Anti-Glare filter 3H for MacBook Pro 14 Model 2021, self-adhesive
Quicklinx: GQJVWS00 Mfr#: D70473
£18.35 ex VAT
£22.02 inc VAT
The DICOTA protective film fulfils a variety of functions: it protects the display from scratches, reduces annoying fingerprints and is easy to attach. It also provides a non-reflective coating for high-resolution displays, guaranteeing a clear view. This makes the anti-glare film the number one choice for you. The film adheres directly to the full surface of the display thanks to the use of a silicone layer.
The anti-glare filters are made with the latest laser cutters and cut to the right size with maximum reliability. The filter is extremely easy to fit. It takes just a few seconds for it to adhere to the full surface of the display and begin carrying out its functions. No more scratches, fewer annoying fingerprints and a high degree of anti-reflection coating for your display. It can be easily removed at any time without leaving any residue.
DICOTA - notebook anti-glare filter
Notebook anti-glare filter
Installation Type
Removable - adhesive
Transparent
Product Material
PET film (3H)
31.06 cm 21.96 cm
20 g
Display Screen Size Compatibility
14"
Touch screen compatible, bubble-free installation, anti-reflective, fingerprint-resistant coating
Apple MacBook Pro (14.2 in)
Product Material
PET film (3H)
31.06 cm
21.96 cm
Thickness
0.155 mm
20 g
14"
Transparent
Display Filter
Installation Type
Scratch Resistant
Limited warranty: - 2 years
Brand: Dicota
