Dicota Anti-glare filter 3H for MacBook Air 15 M2 (2022), self-adhesive
Quicklinx: HG30WS00 Mfr#: D70695
£24.26 ex VAT
£29.11 inc VAT
The DICOTA protective film fulfills a variety of functions: it protects the display from scratches, reduces annoying fingerprints and is easy to attach. It also provides a non-reflective coating for high-resolution displays, guaranteeing a clear view. This makes the anti-glare film the better choice for you. The film adheres directly to the full surface of the display thanks to the use of a silicone layer.
The anti-glare filters are made with the laser cutters and cut to the right size with maximum reliability. The filter is extremely easy to fit. It takes just a few seconds for it to adhere to the full surface of the display and begin carrying out its functions. No more scratches, fewer annoying fingerprints and a high degree of anti-reflection coating for your display. It can be easily removed at any time without leaving any residue. This is a quality German product you can rely on, and is simple and handy to use.
DICOTA - notebook anti-glare filter - 3H
Notebook anti-glare filter - 3H
Installation Type
Adhesive
Image Colour Disclaimer
The displayed product image may be a different colour
Product Material
PET film (3H)
33.5 cm 22 cm
20 g
Display Screen Size Compatibility
15"
Fingerprint-resistant coating, bubble-free installation, self-adhesive, silicone layer back, touch capable, clear view, accurate colour reproduction, residue free, anti-reflection coating
Product Material
PET film (3H)
33.5 cm
22 cm
20 g
15"
Display Filter
Installation Type
Adhesive
Scratch Resistant
Limited warranty: - 2 years
Brand: Dicota
