Dicota Anti-Glare filter 3H for MacBook 13 (2020), self-adhesive
Quicklinx: GDSQWS00 Mfr#: D70373
£18.58 ex VAT
£22.29 inc VAT
The DICOTA protective film fulfils a variety of functions: it protects the display from scratches, reduces annoying fingerprints and is easy-to-attach. It also provides a non-reflective coating for high-resolution displays, ensuring a clear view. This makes the anti-glare film the number one choice for you. The film adheres directly to the full surface of the display thanks to the use of a silicone layer.
The anti-glare filters are made with the laser cutters and cut to the right size with maximum reliability. The filter is extremely easy-to-fit. It takes just a few seconds for it to adhere to the full surface of the display and begin carrying out its functions. No more scratches, fewer annoying fingerprints and a high degree of anti-reflection coating for your display. It can be easily removed at any time without leaving any residue.
DICOTA - notebook anti-glare filter
Notebook anti-glare filter
Installation Type
Adhesive
Transparent
Product Material
PET
29.88 cm 19.47 cm
10 g
Anti-reflective, easy-to-remove, fingerprint-resistant coating, 3H hard-coating, bubble-free installation, silicone layer back, full-surface adhesion, touch capable
Apple MacBook Pro with Retina display (Early 2020)
Product Material
PET
29.88 cm
19.47 cm
Thickness
0.155 mm
10 g
Transparent
Display Filter
Installation Type
Adhesive
Scratch Resistant
Limited warranty: - 2 years
Brand: Dicota
