Dicota Anti-glare filter 3H for Laptop 15.6 Wide (16:10), self-adhesive
Quicklinx: HG2ZWS00 Mfr#: D70690
£33.81 ex VAT
£40.57 inc VAT
The DICOTA protective film fulfills a variety of functions: it protects the display from scratches, reduces annoying fingerprints and is easy to attach. It also provides a non-reflective coating for high-resolution displays, guaranteeing a clear view. This makes the anti-glare film the number one choice for you. The film adheres directly to the full surface of the display thanks to the use of a silicone layer.
The anti-glare filters are made with the laser cutters and cut to the right size with maximum reliability. The filter is extremely easy to fit. It takes just a few seconds for it to adhere to the full surface of the display and begin carrying out its functions. No more scratches, fewer annoying fingerprints and a high degree of anti-reflection coating for your display. It can be easily removed at any time without leaving any residue. This is a quality German product you can rely on, and is simple and handy to use.
DICOTA - notebook privacy filter - 16:10
Notebook privacy filter - 16:10
Installation Type
Adhesive
Product Material
PET
33.5 cm x 0 cm x 21 cm
20 g
Display Screen Size Compatibility
15.6"
Anti-glare, anti-reflective, bubble-free installation, touch screen compatible, fingerprint-proof, silicone layer back, high mechanical resilience, clear view
Product Material
PET
33.5 cm
0 cm
21 cm
20 g
15.6"
Display Filter
Installation Type
Adhesive
Aspect Ratio
16:10
Scratch Resistant
Limited warranty: - 2 years
Brand: Dicota
