Dicota Anti-Glare filter 3H for iPhone 12 PRO MAX, self-adhesive
Quicklinx: G1R1WS00 Mfr#: D70362
Product Range: DICOTA
£10.53 ex VAT
£12.63 inc VAT
The DICOTA protective film fulfils a variety of functions: it protects the display from scratches, reduces annoying fingerprints and is easy to attach. It also provides a non-reflective coating for high-resolution displays, guaranteeing a clear view. This makes the anti-glare film the number one choice for you. The film adheres directly to the full surface of the display thanks to the use of a silicone layer.
The anti-glare filters are made with the latest laser cutters and cut to the right size with maximum reliability. The filter is extremely easy to fit. It takes just a few seconds for it to adhere to the full surface of the display and begin carrying out its functions. No more scratches, fewer annoying fingerprints and a high degree of anti-reflection coating for your display. It can be easily removed at any time without leaving any residue. This is a quality German product you can rely on, and is simple and handy to use.
  • Touch capable
  • Silicone layer on the back allows for full-surface adhesion
  • A clear view at all times
  • Accurate colour reproduction
  • Reduces reflections and fingerprints
  • High mechanical resilience
  • Attaches easily without forming bubbles
  • No residue when removed
DICOTA - screen protector for mobile phone
Screen protector - film
Intended For
Mobile phone
Protection
Scratch-resistant, fingerprint-proof, anti-glare
Product Material
PET film (3H)
7.02 cm 15.05 cm
Thickness
0.205 mm
4.54 g
Transparent
Apple iPhone 12 Pro Max
Intended For
Mobile phone
Protection
Product Material
PET film (3H)
7.02 cm
15.05 cm
4.54 g
Thickness
0.205 mm
Transparent
Brand: Dicota
